Triton 77
    Triton 77
    18dBA for Peaceful Enjoyment
    - Optimal performance and quiet operations with PWM function
    - Thoughtful push pin and clip for easy installation without removing the MB
    - Innovative Up Way Airflow Cooling Technology for efficient over-clocking
    Advantages and Benefits
    Multiple Application with PWM Function
    Triton 77 supports the Intel® Core™ 2 Extreme/Core™ 2 Quad Quad-core CPU (LGA 775) and AMD Athlon™ 64 FX/X2 Dual-Core processors (939/940/AM2). PWM function automatically modulates fan speed according to CPU temperature.
    Immediate Cooling
    The Triton 77 has five copper heat pipes and high-density fins that effectively conduct heat away, maximizing cooling abilities, and ensuring system in stable condition.
    5 High Performance Heat Pipes and Copper Base for Fast Heat Transfer
    Ideal Cooling with DIY Enjoyment
    Triton 77 provides the possibilities for gamers to shift 8 or 9 cm fans. Performance and silence at your control that brings gamers DIY enjoyment.
    Easy-to-Mount for Intel & AMD Platforms - Time Saving and Tool Free
    Unique Ventilation Design
    Innovated up airflow design to create maximum cool air and extend heat exchange time for better heat dissipation.
    Best Performance & Low Acoustics
    Compared Competing Solutions
