Triton 88
    Triton 88
    Exclusive Twin-pillared Design for Ultimate Overclocking Fun (LGA 1366 support)
    - Exclusive twin-pillared design and 120mm inner-fan for extreme overclocking up to 180W
    - Massive heat dissipation area of up to 8500cm2 cooperated with 6 copper heatpipes
    - Allow equipping with three 120mm fans for customization
    Exclusive Twin-pillared Design for Top-of-the-line 180W Overclocking
    ASUS Features
    Exclusive Twin-pillared Design allows three 120mm fan for 180W Overclocking Fun
    Triton 88 utilizes an exclusive twin-pillared heatsink design that; when combined with the 120mm inner-fan, will help in lowering temperatures and create powerful air-cooled performance for extreme overclocking of up to 180W. Furthermore, with the fan positioned within the heatsink, VRM can be protected against high temperatures with the guiding of cool air to critical components near the CPU—ensuring system stability. The exclusive twin-pillared design also allows equipping with three 120mm fans for ultimate customization fun.
    Massive Heat Dissipation Area of up to 8500cm2 for Optimal Cooling
    Triton 88 is equipped with a massive heat dissipation area of up to 8500cm2; while 6 high conductive copper heatpipes and the 120mm LED fan provides maximum airflow and optimal cooling performance. This will ensure that enthusiasts worldwide be able to enjoy overclocking of up to 180W without an inkling of concern. Furthermore, the Triton 88 is equipped with a PWM function that is able to automatically adjust the fan speed according to the CPU’s temperature—providing low acoustics during operation.
    Up-to-date Application
    Triton 88 not only supports multiple applications, and but also the latest Intel® Core™ i7 processor (LGA1366). DIY and gaming enthusiasts worldwide can now easily utilize this top-notch cooler to help ensure that their own PC systems can run faster and more stable than ever before.
    Cooling Chart
