X-Mars Lite
    X-Mars Lite
    The Light Cooler for Dual-Core CPU
    CPU Support
    AMD Athlon™ 64 FX/ X2 all series (Dual-Core)
    AMD Athlon™64/ AMD Sempron™ all series
    Fan Speed 2,000~5,400 rpm ± 10%, Sensor Fan
    Material Cu. Base with Nickel Plating + Al. Fin + 2 Heat Pipes
      Light Weight Cooler for Dual-Core CPU
      Advantages and Benefits
      Superior Cooling Dual-Core
      2 Heat pipes for AMD K8 Athlon™ 64 / FX 59
      Special fin design and high fin density to large heat exchange area
      Best Balance between Performance and Acoustic
      Auto-detect sensor fan that's strongly recommended for both over clock and quiet-system enthusiasts
      Reliable
      Tool-free clip for easy installation
      Only 385g relieves the motherboard from a heavy cooler
      Aesthetics:
      Fins with Electro-Plating and ASUS logo on fan cover to present a fancy looking
      Superior manufacturing process for solid surfaces
      Why ASUS?
      Special heat sink design increases heat exchange area by 27% comapred to traditional square shape
