X-Mars Series
    X-Mars Series
    The Light Cooler for Dual-Core CPU
    CPU Support AMD Athlon 64/ Athlon 64 FX/ Athlon X2 all series (Socket 754/939/940)
    Fan Speed 2,000~5,400 rpm ±10%, Sensor Fan
    Material Electro-plating Aluminum fins, copper base and 2 pipes
    The good combination between fan and heat sink performs great cooling performance with a mere 385g . It's ideal for over-clocking and PC enthusiasts.
    Advantages and Benefits
    Efficient Cooling – Heat pipe technology:
    Excellent contact between Copper base and heat pipes to make efficient heat dissipation.
    X-Mars can easily dissipate the h e at from AMD's latest Dual-Core CPUs.
    Reliable - Less weight on Motherboard
    The best combination of Aluminum stacked fins and 7015 mm fan airflow enables great cooling performance at a mere 385g. This relieves the motherboard from a heavy cooler.
    Easy Assembly – Tool free clip:
    Special tool free clip design allows easy installation.
    Performance and Acoustic:
    The auto detect sensor fan intelligently detects system temperature and automatically adjusts fan speeds. It's strongly recommended for both over clock and quiet-system enthusiasts.
    Aesthetics:
    Aluminum stacked fins with Electro-Plating and ASUS logo on fan cover to present a fancy looking.
    Why ASUS?
    Special heat sink design increases heat exchange area by 27% compared to traditional square shape achieves excellent heat dissipation
