Filter results: 25 Devices
Sort by:
Recommend
Newest
Most Popular
Ratings
Sort Filter
Clear all
By Product
Back to filter
NEW
Bluetooth® wireless gaming headset with Qualcomm® aptX™ Adaptive audio technology, Active Noise cancelation (ANC) technology, ASUS AI Noise-Canceling Microphone, low-latency performance and compatibility with PCs, Nintendo Switch™, smart devices and PS5™
NEW
ROG Falchion RX Low Profile 65% compact wireless gaming keyboard with ROG RX low-profile optical switches, tri-mode connection with ROG SpeedNova wireless technology and Omni Receiver, protective cover, integrated silicone dampening foam, interactive touch panel, and MacOS support
ROG Falchion NX 65% wireless mechanical gaming keyboard with 68 keys, wireless Aura Sync lighting, interactive touch panel, keyboard cover case, ROG NX switches, and up to 450-hour battery life
The ROG Gladius III Wireless AimPoint is a lightweight 79-gram wireless RGB gaming mouse that features a 36,000-dpi ROG AimPoint optical sensor, tri-mode connectivity, ROG SpeedNova wireless technology, swappable mouse switches, ROG Micro Switches, pivoted button mechanism for 0 ms click latency, ergonomic design, ROG Paracord, 100% PTFE mouse feet, six programmable buttons, and mouse grip tape.
ROG Strix Scope RX optical RGB gaming keyboard for FPS gamers, with ROG RX Optical Mechanical Switches, all-round Aura Sync RGB illumination, IP56 water and dust resistance, USB 2.0 passthrough, and alloy top plate
ROG Falchion Ace 65% compact gaming keyboard with pre-lubed ROG NX mechanical switches with ROG switch stabilizer, PBT doubleshot keycaps, sound-dampening foam, interactive touch panel, dual Type-C ports, three keyboard tilt angles, and cover case
ROG Falchion 65% wireless mechanical gaming keyboard with 68 keys, wireless Aura Sync lighting, interactive touch panel, keyboard cover case, Cherry MX switches, and up to 450-hour battery life
ROG Claymore II modular TKL 80%/100% gaming mechanical keyboard with ROG RX Optical Mechanical Switches, detachable numpad & wrist rest, wired & wireless 2.4G modes, extra customizable clicky hotkeys, volume control wheel and wireless Aura Sync.
ROG Azoth gaming custom keyboard with 75 keyboard form factor, gasket mount, three-layer dampening foam and metal top cover, highly customizable with hot-swappable pre-lubed ROG NX mechanical switches, ROG keyboard stabilizers, PBT doubleshot keycaps and lube kit, tri-mode connection with 2.4 GHz SpeedNova technology, OLED display, three-way control knob, three tilt angles, and Mac support
The ROG Keris Wireless AimPoint lightweight 75-gram wireless RGB gaming mouse features a 36,000 dpi ROG AimPoint optical sensor, tri-mode connectivity, ROG SpeedNova wireless technology, swappable mouse switches, ROG Micro Switches, PBT buttons, ROG Paracord, 100% PTFE mouse feet, five programmable buttons, ROG mouse grip tape.
The ROG Gladius III Wireless AimPoint EVA-02 Edition is a 79-gram wireless gaming mouse that features the 36K-dpi ROG AimPoint optical sensor, tri-mode connectivity, ROG SpeedNova wireless technology, swappable mouse switches, ROG Micro Switches, ROG Paracord, 100% PTFE mouse feet, and mouse grip tape.
The ultra-lightweight ROG Harpe Ace Aim Lab Edition is a 54-gram wireless gaming mouse with a pro-tested form factor, 36,000-dpi ROG AimPoint optical sensor, ROG SpeedNova wireless technology, tri-mode connectivity, ROG Micro Switches, five programmable buttons, and synergy profile setting functions with the Aim Lab Settings Optimizer.
ROG Chakram X wireless RGB gaming mouse with next-gen 36,000 dpi ROG AimPoint optical sensor, 8000 Hz polling rate, low-latency tri-mode connectivity (RF 2.4 GHz / Bluetooth / wired), 11 programmable buttons, an analog joystick and hot-swappable micro switch sockets (mechanical / optical ).
ROG Strix Impact II ambidextrous ergonomics gaming mouse featuring 6200-dpi optical sensor, push-fit switch-socket and Aura Sync RGB lighting
ROG Hone Ace Aim Lab Edition large-sized gaming mouse pad is designed to work with Aim Lab X ROG 360 task to help gamers improve their aim. The Hone Ace has a hybrid cloth surface for a smoother glide and better control, a water-, oil- and dust-repellent surface protective nano coating, and a soft nonslip rubber base.
Lightweight 3.5 mm gaming headset with 50 mm ASUS Essence drivers, virtual 7.1 surround sound, compatible with PCs, PlayStation® 5, Nintendo Switch™ and Xbox
Classic asymmetrical wireless gaming mouse with tri-mode connectivity (2.4 GHz, Bluetooth LE 5.2, wired USB 2.0), specially tuned 26,000 dpi with 1% deviation, instant button actuation, exclusive Push-Fit Switch Socket II, laser-engraved ROG aesthetic, Bluetooth rapid pairing technology, ROG Omni Mouse Feet, ROG Paracord and Aura Sync RGB lighting
