Release Note
ZenTalk
[Share] 【Dr. Zen Corner】Leave your questions and our Dr. Zen will answer!
14820 769
Jump to specific floor
Latest Post
nikkojamesreducto PHL Moderator | All posts
Have questions you need answered quickly? Our Dr. Zen are here to help!
Just leave your questions about your ASUS ZenFone below and our Dr. Zen will answer them. Just remember to mention what device you have so they can help you more easily!
@frias.erlwin @mizukishinju17 @hideki elixir @gjmsds112510 @Mouell @KRunchyFries @iamianthugsz @pjengracial @lynnellemmanuel @dRiel @ZenC_ELLe
Technical PR Specialist - Mobile
ASUS Technology Philippines, Inc.
Props
PHL Level 1 | All posts
Hi gud eve may i ask ur help, my brother have a new zenfone max 4 why the camera of zenfine once i capture aome picture it take yellowihs how to be great the picture. Thank to your help
Props
Use pro settings make the wb to 4.5k
Props
I wish the next update make notification and messages turn on the screen and the led never turn off until you see the message...
Props
PHL Level 2 | All posts
When will be the zenui safeguard available in PHIL? It says that it is not compatible in my Z4 max
Props
Zenui 4.0 for zenfone 3 max 5.5? When is the rollout?
Props
How can i relock my bootloader  if accidentally unlock   ~ze552kl
Props
PHL Dr.Zen(PH) | All posts
moisesyaon posted on 2017/10/9 18:55
Hi gud eve may i ask ur help, my brother have a new zenfone max 4 why the camera of zenfine once i c ...
Hi!
You may use Pro mode and adjust your "WB" (aka White Balance) to a higher number Or don't turn your flash on
Props
alvinpantua posted on 2017/10/9 20:47
I wish the next update make notification and messages turn on the screen and the led never turn off  ...
In order for your screen to turn on, use a third-party messaging app which has a setting to turn on the screen whenever a new message arrives
Props
ArBhe posted on 2017/10/9 20:51
ZenUI SafeGuard is available for those with the update for ZenUI 4.0. So just wait for the update for ZenUI 4.0 then you're good to go
Props
Advanced mode
You need to login first Login | Register Now
Points policy of this forum
wishes
Archiver|Mobile ver.|
Fast reply Top Return to list
Share link list
Share by pm
