Release Note
ZenTalk
[ZenFone 5] [190110] ZenFone 5 Lite ZC600KL_RU_14.0400.1901.062  Close
960 0
Jump to specific floor
Latest Post
ZenTalk TWN Super Moderator | All posts
【Version】
14.0400.1901.062
【Model Name】
ZenFone 5 Lite (ZC600KL CPU 630)
【Release Date】
2019/01/22
Since the server pushes update notice to different serial numbersby batches, it may take some days for you to receive the FOTA notice. Thanksfor your patience. You may tap “System updates” in[Settings] >[System] to check if there is new firmware available. Or, youcan also try to manually update firmware by referring to the following link.
【Release Note
1.Update Google Security Patch.
Props
Advanced mode
You need to login first Login | Register Now
Points policy of this forum
wishes
Archiver|Mobile ver.|
Fast reply Top Return to list
Share link list
Share by pm
