Release Note
ZenTalk
[System Settings] How to take a screenshot?
154909 0
Jump to specific floor
Latest Post
ZenTalk_Titan TWN Administrator | All posts
1. Press and hold [Power key]& [Volume Down key] 1 second>>Completed.
The screenshot image will be saved to the folder /Internal storage/ Screenshots.
2. Tap on "Application" >> Tap "Settings" >> Choose "ASUS customized" from options. >> Choose "Key settings">> Choose "Tap and hold to get screenshot" >> Navigate to the screen you want to capture. >> Press and hold icon to capture the screenshot.
3. On home page, access Quick settings and then tap "Quick settings options". -> "Screenshot" function is placed on "tools" (green icons). Tick "Screenshot" and then tap "Save". -> On the page you would like to capture, slide down the screen to access Quick settings and then tap "Screenshot".
Rate
Participants 1ZenCredit +1 Hide Reason
Rfqkml_ + 1 Awesome!! / Mind Blowing!!
View rating log
Props
Advanced mode
You need to login first Login | Register Now
Points policy of this forum
wishes
Archiver|Mobile ver.|
Fast reply Top Return to list
Share link list
Share by pm
