RECO Smart Car and Portable Cam
    Reco Smart in-car and portable camera with real-time streaming, f/1.8 lens and Sony sensor
    • Versatile camera that can be used as an in-car dash cam or portable camera
    • Full HD 1080p video recording with Sony sensor
    • Real-time previews and downloads on smart devices
    • NFC One Touch Engage for easy syncing to smart devices
    • 500GB of ASUS WebStorage free for one year
    • Compatible with standard camera accessories
    Product Image
    One camera. Double the excitement.
    Reco Smart is a small and versatile device that doubles both as an in-car dash cam and portable camera. Connect it with your smart device via Wi-Fi and the ASUS Reco app for real-time previews, or download and share the images and videos. With One-Shot, Time Lapse, and Photo Burst modes, Reco Smart is more than just a car cam, it's one that lets you capture life's little moments.
    Crisp Full HD recording
    Record Full HD 1080p or 720p videos at a smooth 30 frames per second. Reco Smart features a Sony image sensor to give you high quality photos and videos with high color saturation and stunning clarity.
    Capture all night time moments
    Reco Smart has an f/1.8 aperture lens to help you record the tiniest details even in low-light environments. Wide Dynamic Range (WDR) technology improves image quality even under high-contrast lighting – so you're always guaranteed clear images and video.
    Real world example
    Compared to similar car cams, Reco Smart captures clearer, more detailed images in low-light environments.
    • Competitor brand
    • Reco Smart
    See more of the road ahead
    Reco Smart has a 150-degree wide-angle lens that gives you unobstructed views of the sides of your vehicle and the road ahead. It takes great videos and pictures once you're out of the car as well, with its wide-view lens allowing you to capture entire vistas in one frame.
    Instant preview and download with the ASUS Reco app
    The ASUS Reco app lets you connect Reco Smart to your smart devices via Wi-Fi to give you full intuitive control of the camera. You can even preview, download, or share images and videos with friends and family. Its user-friendly interface and NFC Engage makes setting up quick and easy.
    Backup files in the cloud with 500GB of ASUS WebStorage free
    With the ASUS WebStorage, you no longer need to worry about losing your memory card. In the event of an accident, the ASUS Reco app will automatically upload files to the cloud1. Reco Smart comes with 500GB of free ASUS WebStorage2 - that's enough space for over 7,500 video files.
    ASUS WebStorage also lets you easily share files and access them anywhere, on any device, through the cloud. The service automatically syncs your files across all devices, so every file is kept up-to-date.
    1 Auto upload function only works when a smart device is connected to Reco Smart.
    2 500GB of free ASUS WebStorage is only available for one year.
    Get creative with three photo modes
    Reco Smart not only takes single photos or records video; it even has Photo Burst and Time Lapse to help you capture fun and exciting moments.
    • One-Shot
    • Time Lapse
    • Photo Burst
    Parking monitor mode
    Reco Smart can be set to detect movement in front of your vehicle. It will automatically start recording and will continue to do so until it detects no movement for one minute. It keeps a watchful eye on your vehicle even when you're not around.
    Emergency file back-up
    In the event of a collision, the built-in three-axis G-sensor triggers the emergency record function, saving the video and locking it down so it won't be inadvertently deleted. There is also a manual emergency record button that allows you to save videos should you witness an incident. Reco Smart can also be programmed to send out an emergency text message to a designated contact to call for help.
    Compatible with a wide range of camera accessories
    Reco Smart has a standard 58mm filter ring and 1/4-inch screw mount, so it's compatible with tripod mounts, filters, and other accessories.
    *Above accessories are not included in the box.
