Sort Filter
The ROG Scabbard II XXL Edition 20 is a large gaming mouse pad with a water-, oil-and dust-repellent surface and anti-fray, flat-stitched edges, plus a nonslip rubber base
ROG Strix Morph 96 X Wireless custom gaming keyboard with hot-swappable ROG NX V2 mechanical switches, south-facing PCB, tri-mode connectivity, ROG SpeedNova wireless technology, gasket mount and dampening layers, three adjustable tilt angles, wrist rest, durable ROG doubleshot ABS keycaps, and MacOS support
A customizable wireless MMO gaming mouse, featuring 12 programmable buttons, five weight-and-balance configurations, and an advanced charging dock that doubles as a wireless receiver.
An ergonomic esports gaming mouse built through sports-science research and refined for competitive play, the ROG Gladius IV Ace features customizable weight, ROG SpeedNova 8K Gen II wireless, AimPoint Pro 65K sensor, Zone Mode, and Gear Link
- 25L capacity accommodates everyday essentials, gaming gear, and up to an 18-inch laptop, providing ample space for daily carry and travel.
- Multiple storage compartments provide dedicated space for laptops, accessories, and gaming gear, keeping everything organized and within easy reach.
- Convenient exterior pockets keep frequently used essentials protected and always within reach.
- Ergonomic shoulder straps, breathable back padding, and travel-ready features provide lasting comfort and stability throughout the day.
USB-C® wired gaming headset for PC, Switch, PlayStation, 50 mm ROG titanium-plated diaphragm drivers, 10 mm super-wideband boom microphone, lightweight 300-g design, plus parametric EQ settings
ROG Keycap Mystery Box Edition 20 features unique ROG-inspired designs for a surprise unboxing experience. Each box contains an exquisitely-crafted collectible keycap.
ROG Azoth Extreme Edition 20 customizable gaming keyboard featuring an aluminum-alloy chassis, carbon fiber positioning plate, adjustable gasket mount, full-color OLED touchscreen with three-way control knob, extended wrist rest, magnetic feet, tri-mode connectivity with 2.4GHz SpeedNova technology, hot-swappable pre-lubed ROG NX Edition 20 mechanical switches, translucent keycaps, and a commemorative black-and-gold design
Designed in collaboration with Team Vitality, the ROG Hone Control Ace L Vitality Edition features a control-focused cloth surface for strong stopping power and consistent micro-adjustments, making it a trusted addition to the ROG Ace Esports lineup.
With a limited-edition design that commemorates the 20th anniversary of ROG, the Harpe II Extreme Edition 20 features a shape co-developed with esports pros, the new 65,000dpi ROG AimPoint Pro 65K sensor, and industry-leading 8,000Hz wireless performance powered by ROG SpeedNova technology.
- 6-in-1 Connectivity: Features HDMI 2.1, three USB-A ports, a 1Gb Ethernet port, and up to 80W Power Delivery.
- 4K Display Output:The HDMI 2.1 port supports up to 4K@144Hz or 8K@30Hz, along with VRR, ALLM, and HDR.
- Stand Design: Maintains the optimal viewing angle while keeping exhaust vents clear.
- 4 RGB Lighting Modes: Creates an immersive and unified gaming atmosphere.
- Black and translucent gold with slash pattern design & stainless gold steel plate, celebrating ROG 20th anniversary
- 360-degree silent skate wheels designed for enhanced shock absorption and smoother rolling
- A 100% polycarbonate shell reflects the ROG SLASH design while offering superior protection
- A hard case design and aluminum frame offer high protection during your travels
- A TSA-approved lock allows you to keep your gear secure when traveling by air
- Organizer compartments keep all of your peripherals in place
- 20-inch carry-on suitcase with a 25L capacity, offering ample space for everyday essentials and gaming gear while remaining travel-friendly.
- Quick front access keeps gaming gear and up to a 16-inch laptop within easy reach.
- HINOMOTO miraclent® 360° silent wheels deliver smooth, quiet mobility, while self-aligning ROG logo caps reinforce the premium ROG identity.
- Dual TSA locks provide independent security for both the front access and main compartments, giving added convenience and peace of mind while traveling.
- Signature ROG aesthetics with premium design details that extend the ROG identity beyond gaming.
- Black and translucent gold with slash pattern design, celebrating ROG's 20th anniversary
- 26L capacity, accommodating full-size 18-inch laptops
- Roll top design expandable via FIDLOCK magnetic quick release buckle
- Dedicated laptop compartment and multiple pockets keep all your gear organized
- Breathable back rest design and adjustable chest strap reduce pressure when carrying heavy loads
- Side zipper on the main compartment for quick, grab-and-go access.
ROG Kithara gaming headset with ROG-Tuned 100mm HIFIMAN planar magnetic drivers, open-back architecture, full-band MEMS boom microphone, dual 3.5mm input, 4.4mm balanced, 3.5mm, 6.3mm single-ended plugs
Rugged yet refined, the ROG Archer Backpack 16 combines Cordura® durability, expandable storage, and ergonomic support — made to carry more and endure every journey.
Compact yet powerful, the ROG Archer Messenger 14 combines durable Cordura® fabric, modular storage, and ergonomic comfort — crafted for gamers, creators, and everyday explorers.
- 260W Total Output: Power for everything on your desk, all at once.
- 1.9" LCD Display + Knob: Displays real-time charging wattage, transfer speed, and resolution — switch Charging Modes instantly with the physical knob.
- 5 Charging Mode: Wattage intelligently distributed for every scenario, from focused fast-charging to quiet overnight power.
- High Speed 10Gbps Transfer: Front-side USB-C ports support 10Gbps high-speed data transfer, ideal for external SSDs or transferring large game libraries in seconds
- 4K Display Output: Delivers crystal-clear display output up to 4K@144Hz or 8K@30Hz, with VRR and Game Mode support for smooth, tear-free visuals
- Aura Sync RGB: Supports 5 lighting effects and syncs with your entire ROG ecosystem for a fully cohesive desktop setup.
