ASUS ZenWiFi
Ideal Mesh Networking Solution For Thick Walls!
Whole-Home Coverage
The ZenWiFi AX Hybrid system includes a pair of ASUS AX1800 WiFi routers with built-in 1300 Mbps HomePlug AV2 powerline networking. It features unique technologies that give you superfast, reliable and secure WiFi connections – inside or outside your home!
Ideal For Overcoming Thick Walls
The ZenWiFi AX Hybrid combines WiFi and powerline technologies, providing the ideal solution for homes with thick or metal-reinforced walls that cause WiFi backhaul problems. Backhaul data for the mesh network can be sent via powerline over your home's electrical wiring, so home devices can connect at full AX1800 WiFi 6 speeds. The HomePlug AV2 MIMO standard is almost 2X faster* than the previous standard.
*Based on ASUS lab tests. For best results, please connect the unit directly to a wall socket. The use of extension leads may affect performance.
Learn more about HomePlug AV2 MIMO and backhaul.
HomePlug AV2 MIMO Ensures High Bandwidth
ASUS ZenWiFi AX Hybrid uses HomePlug AV2, with MIMO and beamforming technologies that use special signal techniques to greatly increase the available bandwidth over electrical circuits to 1300 Mbps. That's almost twice as fast as the previous HomePlug standard!*
* The router should be connected directly to a 3-pronged wall socket.
HomePlug AV2 MIMO
HomePlug AV2 SISO
Smart & Flexible Backhaul Configuration
ASUS ZenWiFi AX Hybrid gives you three alternative backhaul options: powerline, Ethernet and WiFi. The router intelligently chooses the most reliable method for you, based on connection quality. If you prefer, you can also manually choose the type of backhaul connection.
Powerline Backhaul
Ethernet Backhaul
Wireless Backhaul
WiFi 6
True 8K Streaming
ZenWiFi AX Hybrid puts your WiFi into top gear! With a total bandwidth of up to of 1800 Mbps, it's up to 1.4X faster* than WiFi 5 routers **.
* Compatible WiFi 6 device required.
** The data compares speed of 2X2 11ax on 5GHz 80 MHz bandwidth with 1024QAM modulation to speed of 2x2 11ac on 5GHz 80MHz with 256QAM modulation.
The smoothest WiFi for all your devices
WiFi 6 (802.11ax) is engineered to cope with multiple devices, so even if your home's packed with WiFi devices, you'll still enjoy fast WiFi everywhere. WiFi 6 also uses special Target Wake Time technology that reduces the power consumption of connected devices by up to 7X, extending their battery life*.
Works with any WiFi device
WiFi 6 is fully compatible with all generations of WiFi, so you can connect any device to ZenWiFi AX Hybrid, no matter if it uses 802.11ac, 802.11n or other previous WiFi standards.
Instant Guard Makes Public WiFi Secure
ASUS Instant Guard uses the power of your ZenWiFi AX Hybrid to add rock-solid VPN security to any public WiFi connections you use. It helps protect your private information such as credit card details, business data, emails and more.
Flexible Network Naming
Uniquely, ZenWiFi lets you choose how you name your WiFi networks: a single name for everything, or separate names for each frequency band. The choice is yours!
Easier-than-ever Setup
3-step setup with the ASUS Router app
1
Turn on ZenWiFi AX Hybrid
2
Create a WiFi network name and an admin account
3
Wait for several minutes, and you're done!
What makes ZenWiFi AX Hybrid setup so easy?
- One-time setup, with auto synchronization for all the hubs in each package
- Hassle-free: each unit can work as the main router or an extender node
Safer Place for Everyone
AiProtection Pro with Advanced Parental Controls is free for life. It gives you total peace of mind, and you can keep an eye on everything that's happening on your network via the mobile app.
Some routers only offer 3 years of protection, ASUS AiProtection has you covered for the life of your product.
Intrusion Prevention System (IPS) blocks all common internet-based attacks.
AiProtection uses Trend Micro's official database to identify and block known malicious sites, preventing infection even before you click.
Even if an already-infected device is connected to ZenWiFi, AiProtection prevents any personal data on the device from being compromised.
Parental Controls
URL filter and scheduling allow you to protect your family from inappropriate content and unhealthy Internet usage behavior.
More Stable WiFi with Wired Connections between ZenWiFi Hubs
If you have Ethernet ports in your walls, you can set ZenWiFi AX Mini to use Ethernet backhaul, reserving all WiFi bands for your wireless devices for even more stable and reliable networking.
AiProtection has everything you need in one place: it's super-easy to view or change security settings on each of your family member's devices, so your kids can be safer when surfing!
View each family member's internet activity on a clear graphical dashboard showing the peak time and what kind of content they are viewing. You can group devices that belong to your children to view aggregated data and apply scheduled block times and content filters with just a few taps.
Choose the preset that matches the age range of your family members, and it will suggest internet access time schedules and content filters for all their devices.
Reserve valuable family time or help your children develop responsible behavior by selecting scheduled time periods to block internet access on specific devices.
Block specific categories of mobile apps and websites, and apply these settings to all devices belonging to individual family members. The advances filtering integrates Trend Micro's Deep Packet Inspection (DPI) engine to filter not only by website URL, but also by the internet packets themselves, which means it filters content viewed not only in a web browser, but also within mobile apps on your devices.
Smart Looks for Smart Homes
ASUS ZenWiFi AX Hybrid works perfectly with smart-home services- including Alexa skills.
Read more
AiMesh Technology
Easy setup. Flexible management.
Even non-experts can quickly set up AiMesh technology, while more experienced users will appreciate the comprehensive advanced networking features.
How do I expand my network?
Flexible and Scalable Wireless Networking
If you need more coverage or new functions, you can simply add another compatible router to your AiMesh network at any time!
Learn more about AiMesh
- The terms HDMI and HDMI High-Definition Multimedia Interface, HDMI trade dress and the HDMI Logos are trademarks or registered trademarks of HDMI Licensing Administrator, Inc. in the United States and other countries.
- Actual data throughput and WiFi coverage will vary from network conditions and environmental factors, including the volume of network traffic, building material and construction, and network overhead, result in lower actual data throughput and wireless coverage.
- Quoted network speeds and bandwidth based on current IEEE 802.11ac specifications. Actual performance may be affected by network and service provider factors, interface type, and other conditions. Connected devices must be 802.11ac-compatible for best results.
- WPA/WPA2 enterprise is only available on single router, is not available under AiMesh mode.
- When traditional QoS is enabled, there will be limitations due to the actual Internet service bandwidth and different environment, and there may be a risk of speed reduction.
- Due to the different power supply requirements on USB external hard disk and 4G/5G Modem device, to ensure that the external device can be used stably, if the USB external device exceeds the standard USB 2.0 (5V/500mA) and USB 3.1 Gen 1 (5V/900mA) power supply requirements, you need to use it with an independent external power supply.
- If you use the product in conjunction with a third party service, you are responsible for complying with the third party provider's terms and conditions and privacy policy and are also at the risk of such use. ASUS does not provide support or guarantee continuous integration support for products that are not part of ASUS.
- The device is restricted to indoor use only when operating in the 5150-5350 MHz frequency band in certain regions, including the EU, Asia-Pacific countries, Australia, and Canada. Outdoor use in this band may be prohibited or require regulatory approval. Check local regulations before deployment.
- For models with Time machine support, starting with macOS 26 (Tahoe), Time Machine no longer supports creating new backups on USB-connected storage devices. Existing Time Machine drives that were previously configured remain compatible and can continue to be used for backup and restoration.
