SBW-06D2X-U PRO
    SBW-06D2X-U PRO
    BDXL Support - Maximum Data Storage up to 128GB
    • Mac and Windows OS Compatible
    • BDXL format support
    • Extreme 6X Blu-ray writing speed
    • 2011 iF Design Award
    • 2012 Taiwan Excellence Award
    • Blu-ray 3D support, 2D to 3D DVD conversion, DVD upscaling to HD 1080p
    • Dolby EX and DTS-HD (5.1 channels)
      Product Image
      SBW-06D2X-U,BDXL Support - Maximum Data Storage up to 128GB
      BDXL™ Format Support
      Allows users to burn huge amounts of data on a single Blu-ray disc, up to 100GB on BD-R(TL), and 128GB on BD-R(QL)
      The Best Burning Quality
      Auto Tuning Power technology ensures optimized power to burn a disc with the best quality
      6X Blu-ray High Speed
      Turbo Engine enables 6X Blu-ray writing
      Double the Security On-the-Go
      Disc Encryption II doubles the security with password-controls and hidden-file function, protecting important user data
      Drag-and-Burn
      Friendly interface with only three simple steps to burn a disc, making the process easier than ever
      Drag-and-Burn
      Flexible Dual Positioning
      Vertical and horizontal two-way placement
      Blu-ray 3D Support
      • ASUS supports latest Blu-ray 3D technology, but the Blu-ray playback software is subjected to change by area. Please check with your supplier for exact offers.
      • Learn more about Blu-ray 3D
      Award Winning Design
      The 2011 iF Design Award product design is inspired from miniaturized architectual forms, using elegant squared lines and a unique stand
