https://techinstyle.asus.com/hub/mobile/
    ROG USB-C Cable
    ROG USB-C Cable
    Easy charging with the ROG USB-C Cable
    • 1.2m cable to charge your USB-C devices
    • Enjoy USB 2.0 data speeds of up to 480Mbps
    • Supports up to 3A of power output for fast charging
    • Stringently-tested for durability and safety
      Product Image
      CHARGING MADE EASY
      With the ROG USB-C Cable you can easily charge your USB-C devices, or transfer your photos and data at smooth USB 2.0 speeds.
      CONVENIENT
      1.2m braided USB-C cable for added convenience
      DURABILITY AND SAFETY
      Meets US DoE Level VI and ERP Tier 2 requirements; stringently-tested for toughness, durability, and safety.
      Cable life test Tensile resistance Bending strength
      10,000 40N 3000
      times* times
