ZenPower Pro (PD)
ZenPower Pro (PD)
view on your table
View the model in 3D
asus zenpower pro
The World's Lightest and Smallest Portable Notebook Power Bank
ASUS ZenPower Pro PD is the world's lightest and smallest power bank with Power Delivery 3.0 (PD 3.0) fast-charge technology. ZenPower Pro PD is easily carried with your notebook, smartphone and tablet; and with fast-charge ports and a reversible USB Type-C™ (USB-C™) connector, you can charge two devices at once – wherever you are!
45W
USB-C fast charging
13600
mAh battery
PD 3.0 Fast-Charge and Recharge Technology
ZenPower Pro PD features PD 3.0 fast-charge technology with a massive 45W output for the fastest charge and recharge times. It intelligently detects your device and adjusts charging modes for the quickest and safest charge, without shortening the lifespan of your battery. The USB-C port supports two-way charging, so you can charge devices or top up ZenPower Pro PD via the same port.
PD 3.0
supported portable charger
supported portable
charger
charger
45W
High 45W output for fast charging
High 45W output
for fast charging
for fast charging
USB-CTM
smart, fast two-way charging
Charge UX390UA for 30 mins from 5%
Connect Any Device for Superfast Charging
The power-packed 13600mAh battery of ZenPower Pro PD charge your devices rapidly, giving you more time for work or entertainment, ZenPower Pro PD anytime and anywhere! It comes equipped with the latest USB-C™ port, so there's no need to worry about incompatible plugs, simply connect your notebook, tablet, smartphone or anything else for speedy charging.
2.5times
Full charges on ZenFone 5
Full charges on
ZenFone 5
ZenFone 5
1.5times
Full recharges for ASUS Transformer 3 Pro
Transformer 3 Pro
Transformer 3 Pro
USB-C™ apply for
Smartphone
Notebook
Nintendo Switch
Notebook
Nintendo Switch
Exclusive ASUS PowerSafe Protection
ZenPower Pro PD exclusive ASUS PowerSafe technology monitors temperature, controls both input and output voltage, and guards against short circuits to safeguard your products when charging.
1.5X
longer lifespan
11types
protection
temperature
protection
protection
reset protection
short circuit
protection
protection
input over voltage
protection
protection
output over
voltage protection
voltage protection
input reverse
direction protection
over charge/ over
discharge protection
output over
current protection
current protection
cell PTC protection
adapter protection
JEITA protection
Certified for Total Confidence
ZenPower Pro PD has been certified for safety, electromagnetic-interference (EMI) levels, and charging performance by seven leading international testing organizations. It also conforms to International Electrotechnical Commission (IEC) standards, so you can carry it anywhere in total confidence!
7
International
Certifications
Certifications
Underwriters
Laboratories Inc.
Laboratories Inc.
Federal
Communications
Commission
Communications
Commission
Product Safety of
Electrical Appliance
& Materials
& Materials
Bureau of Standards,
Metrology and
Inspection
Metrology and
Inspection
Conformité
Européenne
Européenne
EurAsian
Conformity
Conformity
IECEE
Certification Body
Scheme
Certification Body
Scheme
More than a Power Bank!
ZenPower Pro PD does more than you can imagine! It has a high-intensity LED flashlight to light up wherever you go – with enough power to shine for up to 5 days.
Built to Last – Ready for Anything!
ZenPower Pro PD is built to last! It is subjected to 5000 USB inserts and removals, put through extreme temperature tests, as well as drop tested from 100cm, repeatedly. ZenPower Pro PD is tested to the extreme to make sure it's ready for whatever you throw at it!
5000times
USB insert tests
100cm
drop test
-40°
lowest temp
Related products
- The terms HDMI and HDMI High-Definition Multimedia Interface, HDMI trade dress and the HDMI Logos are trademarks or registered trademarks of HDMI Licensing Administrator, Inc. in the United States and other countries.
undefined (0/4)
Need Help?
