Xonar U7 MKII
Xonar U7 MKII 7.1 USB sound card with headphone amplifier, 192kHz/24-bit HD sound, 114dB SNR
  • True 7.1-channel, 192kHz/24-bit HD surround sound with a 114dB SNR from a compact, USB-powered device
  • Integrated headphone amplifier boosts sound and reveals musical details
  • Dedicated headphone and mic volume controls enable instant audio adjustments for better gaming and media streaming experiences
  • Clickable volume control knob for convenient switching between headphone and speaker output
  • Sonic Studio software suite with intuitive, single-screen interface and Sonic Radar Pro for mapping opponent locations in first-person shooters
Xonar U7 MKII
Videos
The first set of Evagelion PC in Vietnam 😱 / ROG x Evagelion Build
PC more than 100 full Rog Strix #Shorts #satisfying #satisfyingvideo #ODDLYSATISFYING
Case for office brothers
Enjoy stunningly detailed audio with this plug-and-play USB sound card
Xonar U7 MKII is designed to provide the best audio experiences for PC gaming and media streaming. It delivers stunningly clear and impactful sound when listening with headphones or speakers that far surpasses onboard PC audio hardware. With convenient USB connectivity, Xonar U7 MKII gives you instantly upgraded sound quality without the need to open your PC case to install an internal sound card. Its USB design also eliminates the need for a separate power supply, so just connect one cable and start listening.
Powerful sound from a compact and portable device
Xonar U7 MKII engineering overcomes the space and power supply limitations of other external USB-based audio devices to offer precise and immersive 7.1-channel surround. Sound processing uses 192kHz/24-bit fidelity for true high definition output, maintaining consistent quality across all surround channels.
114dB signal-to-noise ratio (SNR)
Up to 16X audio clarity compared with the SNR ratios of average onboard audio.
Hyper Grounding technology
Exclusive ASUS Hyper Grounding PCB fabrication ensures strong signal insulation to reduce distortion and interference, also known as component crosstalk.
Digital to analog converter (DAC)
High quality Cirrus Logic® CS4398 DAC (digital-to-analog converter) brings clarity with excellent signal-to-noise ratio (SNR) and low total harmonic distortion (THD)
Integrated headphone amplifier pumps up every sound detail
Since many gamers choose to refrain from disturbing others while insisting on the best sound quality, Xonar teams integrate a headphone amplifier on Xonar U7 to boost immersive headphone output.
Designed for gaming and media streaming
Dedicated headphone and microphone volume enable instant audio level adjustments without the need to pause your game or navigate software menus, ensuring uninterrupted gaming and media streaming experiences.
Fast and easy switching between headphone and speaker output
The headphone volume control knob doubles as a clickable output selector for instant, convenient switching between listening with headphones and speakers.
Plug-and-play USB convenience
With its USB design, Xonar U7 MKII dramatically upgrades your PC's audio performance simply by plugging it in. It draws power directly from the USB port, eliminating the need for a separate power adapter. Its compact design fits almost anywhere and is easily portable, so you can bring it with your laptop and enjoy great-sound audio on the go.
Total Audio Control
Take full audio control with Sonic Studio
Xonar U7 MKII features the latest Sonic Studio software suite for full control over every sound technology, from equalization (EQ) to 7.1-speaker level-balancing. Sonic Studio has a single navigation page that puts everything in front of you, with an intuitive point-and-click interface that allows you to pre-set audio profiles to suit different audio requirements.
Gain the gaming edge with Sonic Radar Pro!
Fire up your favorite game and Sonic Radar Pro displays a ‘radar' HUD (heads-up display) that pinpoints in-game actions relative to your position, so you'll know exactly where you are on the battlefield and what's happening around you!
Works perfectly with Windows 10
Xonar U7 MKII is fully compatible with Windows 10, so you can enjoy the ultimate audio experience without any hassles.
Related products
previous image
next image
