Filter results: 22 الجهاز
صنف:
Recommend
حسب المنتج
الأكثر شهرة
Sort Filter
مسح الكل
حسب المنتج
الرجوع للتصفية
New
ROG Falchion RX Low Profile 65% compact wireless gaming keyboard with ROG RX low-profile optical switches, tri-mode connection with ROG SpeedNova wireless technology and Omni Receiver, protective cover, integrated silicone dampening foam, interactive touch panel, and MacOS support
ROG Falchion 65% wireless mechanical gaming keyboard with 68 keys, wireless Aura Sync lighting, interactive touch panel, keyboard cover case, Cherry MX switches, and up to 450-hour battery life
ROG Falchion Ace 65% compact gaming keyboard with pre-lubed ROG NX mechanical switches with ROG switch stabilizer, PBT doubleshot keycaps, sound-dampening foam, interactive touch panel, dual Type-C ports, three keyboard tilt angles, and cover case
ROG Azoth gaming custom keyboard with 75 keyboard form factor, gasket mount, three-layer dampening foam and metal top cover, highly customizable with hot-swappable pre-lubed ROG NX mechanical switches, ROG keyboard stabilizers, PBT doubleshot keycaps and lube kit, tri-mode connection with 2.4 GHz SpeedNova technology, OLED display, three-way control knob, three tilt angles, and Mac support
The ROG Gladius III Wireless AimPoint is a lightweight 79-gram wireless RGB gaming mouse that features a 36,000-dpi ROG AimPoint optical sensor, tri-mode connectivity, ROG SpeedNova wireless technology, swappable mouse switches, ROG Micro Switches, pivoted button mechanism for 0 ms click latency, ergonomic design, ROG Paracord, 100% PTFE mouse feet, six programmable buttons, and mouse grip tape.
The ultra-lightweight ROG Harpe Ace Aim Lab Edition is a 54-gram wireless gaming mouse with a pro-tested form factor, 36,000-dpi ROG AimPoint optical sensor, ROG SpeedNova wireless technology, tri-mode connectivity, ROG Micro Switches, five programmable buttons, and synergy profile setting functions with the Aim Lab Settings Optimizer.
Lightweight 3.5 mm gaming headset with 50 mm ASUS Essence drivers, virtual 7.1 surround sound, compatible with PCs, PlayStation® 5, Nintendo Switch™ and Xbox
ROG Gladius II Wireless ergonomic RGB gaming mouse with dual 2.4GHz/Bluetooth wireless connectivity, advanced 16000-dpi sensor, ROG-exclusive switch socket design, and Aura Sync lighting
