Release Note
ZenTalk
[ZenFone 4] [180302] ZenFone 4 Pro ZS551KL_ WW_15.0410.1802.34  Close
4391 0
Jump to specific floor
Latest Post
ZenTalk TWN Super Moderator | All posts
【Version】
15.0410.1802.34
【Model Name】
ZenFone 4 Pro(ZS551KL)
【Release Date】
2018/03/12
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note
1.Upgrade to Android O.
2.Software update to Android 8.0 Oreo. Internal storage will decrease slightly after update, suggest to backup data before starting the software update.
3.Swipe up to All apps: After OS upgrade, launcher has some important changes- swipe up to all apps, all app icon could be changed.
4.Power consumption improvement.
5.Long screenshot: screenshot adds "Long screenshot" function.
6.Substitute Cast function for PlayTo function
Props
Advanced mode
You need to login first Login | Register Now
Points policy of this forum
wishes
Archiver|Mobile ver.|
Fast reply Top Return to list
Share link list
Share by pm
