Gaming headset boasts 60mm neodymium-magnet drivers, 90% environmental-noise cancellation, and PC, Mac, PS4 and smart-device compatibility
    • Thunderous 60mm drivers-Precise positioning and immersive game audio
    • Environmental noise cancellation- Clear in-game communication
    • Cross-platform flexibility-PC, Macs, PS4, smartphones and tablets compatible
    • Foldable ear cups-Travel friendly design
    Product Image
    Unleash your gaming instincts
    Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood, as it is in ours. LEARN MORE
    Sharpen your hearing
    Strix Pro is powered by the 60mm neodymium-magnet drivers giving you the most punchiest and accurate sound fidelity. No worries about annoying mechanical keyboard sound to be heard by your teammates, the ENC (environmental noise cancellation) technology intelligently filters out over 90% noises. Equipped with Strix Pro, become a predator natural enemy to all your opponents.
    Thunderous 60mm neodymium-magnet drivers
    If you've not felt the power of 60mm neodymium-magnet drivers then listen with Strix Pro— experience unrivalled punch and audio immersion which is utterly convincing. When gaming you will hear every gunshot and know enemies are nearby from their footsteps alone. Then, switch to audio for roomy stadium rock, crisp and clear spoken-word listening or movie soundtracks that sound so real.
    The built-in microphone detects and counters environmental noises
    Game with
    enhanced clarity
    Filters out more than 90% environmental noise
    The USB-powered control box includes a built-in microphone that actively detects and counters more than 90% of environmental noises1 such as mechanical keyboard tapping and speech, so teammates aren't distracted in chat by noises that might be occurring around gamer.
    Connect to PC/Mac
    Works with both PCs and Mac computers...
    Forget compatibility worries with Strix Pro because it works with most popular devices. The control box is accompanied by a 1.5m extension lead with separate headphone and mic plugs, for great compatibility with PC and Mac.
    Connect to PS4/Smartphone/Tablet
    …and even consoles, smartphones and tablets
    Strix Pro is also perfect for smartphones, tablets and PlayStation® 4, thanks to the four-pole 3.5mm audio/mic combined adapter. Plug into your smart device to keep in touch with family or friends on the road or PlayStation® 4 to enjoy gaming fun. Our research shows that 1.2m cable is a perfect length for mobile or PlayStation® 4 joystick use—no more knots and tangles!
    Game everywhere
    Travel-friendly foldable design
    The foldable design allows ear cups to lay flat, ideal for packing and bringing to a LAN party or tournament. The detachable microphone boom is perfect for easy removal, travel and storage. Weighing just 320g, Strix Pro is also highly portable and supremely comfortable to wear.
    1 Connect via USB to activate the Environmental noise cancellation (ENC) feature. The ENC performance result is tested and verified in ASUS lab, and actual performance may vary depending on distance from noise source, room size, placement and other factors.
