Filter results: 238 Devices
Sort by:
Recommend
Newest
Most Popular
Ratings
Sort Filter
Clear all
By Product
Series
Back to filter
NEW
ROG Dye-Sub PBT Keycaps for ROG NX switches are made of premium, durable PBT and feature dye-sublimated legends and stylish ROG elements.
NEW
85g
Work faster and smarter with the new ASUS SmartO Mouse Silent Plus. Its meticulously crafted low-profile silhouette is ergonomically designed for comfortable all-day use. A high-performance sensor ensures precise tracking on almost any surface, while a special switch design ensures almost-silent mouse clicks. Plus, an elastic loop provides convenient portability. ASUS SmartO Mouse Silent Plus has a new Green Tea Latte finish and includes Armoury Crate software for more customization options to give you unmatched style and functionality.
NEW
ASUS Marshmallow Mouse MD100 Lite adds a handy strap that makes it easy to carry around. To keep things moving, this energy-efficient mouse lasts up to a year on a single AA battery, and it features switches with a 10-million-click lifespan. A quick press of a button allows you to switch between three DPI levels, and 100% PTFE mouse feet provide a smooth glide on any flat surface.
NEW
Bluetooth® and 2.4 GHz wireless gaming headphones with ROG SpeedNova wireless technology, 24-bit 96 kHz audio and Dirac Opteo™, Bone-Conduction AI Microphones, Adaptive ANC with Auto mode, up to 46-hour battery life, Hybrid Multipoint, plus ASUS Aura RGB lighting support
NEW
The ROG Keris II Ace is an ultralight 54-gram ergonomic gaming mouse with a shape tested by pro FPS players. Equipped with 42,000-dpi ROG AimPoint Pro optical sensor, ROG Optical Micro Switches and the ROG SpeedNova wireless technology, the Keris II Ace is also able to enhance gaming performance even further with the ROG Polling Rate Booster, which supports polling rates up to 4,000 Hz in wireless mode and up to 8,000 Hz in wired mode.
NEW
ROG Falchion RX Low Profile 65% compact wireless gaming keyboard with ROG RX low-profile optical switches, tri-mode connection with ROG SpeedNova wireless technology and Omni Receiver, protective cover, integrated silicone dampening foam, interactive touch panel, and MacOS support
The ROG Strix Impact III Wireless is an ultralight 57-gram compact gaming mouse that features ROG SpeedNova wireless and Bluetooth® modes with long-lasting battery life. The ROG AimPoint optical sensor offers precise tracking, and the ROG Omni Receiver allows for connections to a keyboard and mouse via a single dongle.
ROG Azoth gaming custom keyboard with 75 keyboard form factor, gasket mount, three-layer dampening foam and metal top cover, highly customizable with hot-swappable pre-lubed ROG NX mechanical switches, ROG keyboard stabilizers, PBT doubleshot keycaps and lube kit, tri-mode connection with 2.4 GHz SpeedNova technology, OLED display, three-way control knob, three tilt angles, and Mac support
The ROG Ranger Carry Sleeve 16 provides all-weather protection for your laptop and other gaming gear with its stylish water-repellent construction. Detachable buckles and an adjustable shoulder strap add flexibility, allowing the Sleeve to be carried in three different ways.
16"
The ASUS Vigour Backpack combines classic minimalist design with impressive versatility. Though lightweight, it offers ample room to accommodate up to a 16-inch laptop and features a magnetic front pocket and additional concealed pockets for daily essentials. Its water-repellent PU leather construction ensures exceptional durability and longevity.
The ROG Harpe Ace Mouse Grip Tape EVA-02 Edition is a pre-cut anti-slip mouse grip that provides you with a secure grip and an added bit of flair.
The ROG Gladius III Wireless AimPoint EVA-02 Edition is a 79-gram wireless gaming mouse that features the 36K-dpi ROG AimPoint optical sensor, tri-mode connectivity, ROG SpeedNova wireless technology, swappable mouse switches, ROG Micro Switches, ROG Paracord, 100% PTFE mouse feet, and mouse grip tape.
The ROG Keycap Set for ROG RX Switches EVA-02 Edition offers EVA-inspired keycaps for ROG RX optical mechanical Switches
ROG Strix Scope RX EVA-02 Edition optical RGB gaming keyboard for FPS gamers, with EVA-inspired design, ROG RX optical mechanical switches, all-round Aura Sync RGB illumination, IP57 waterproof and dust resistance, USB 2.0 passthrough, and alloy top plate
