Filter results: 104 Device
Sort by:
Recommend
Newest
Most Popular
Ratings
Sort Filter
Clear all
By Product
Cancel
Apply
Back to filter
New
ROG Falchion Ace HFX
ROG Falchion Ace HFX 65% analog gaming keyboard with pre-lubed ROG HFX Magnetic Switches, Rapid Trigger toggle, Speed Tap Mode, interactive touch panel, 8000 Hz polling rate, five-layer dampening and silicone gasket mount, dual Type-C ports, three tilt angles, and cover case
New
ROG Harpe Ace Mini
The ROG Harpe Ace Mini is an ultralight 49-gram semi-symmetrical gaming mouse with a shape approved by pro FPS players. Equipped with 42,000-dpi ROG AimPoint Pro optical sensor and ROG Optical Micro Switches, the ROG Harpe Ace Mini displays industry-leading wireless performance with SpeedNova wireless technology and supports up to 8,000 Hz wireless polling rate (compatible with the ROG Polling Rate Booster).
New
ROG Harpe Ace Extreme
The ROG Harpe Ace Extreme is a high-end, 47-gram wireless gaming mouse made out of carbon fiber composite, is equipped with 42,000-dpi ROG AimPoint Pro Optical Sensor and ROG Optical Micro Switches, and also comes with glass mouse feet and 8,000 Hz ROG Polling Rate Booster.
New
ROG Delta II
Tri-mode wireless gaming headset with ROG SpeedNova, 50 mm titanium-plated diaphragm drivers, and refined wireless sound signature, 10 mm super-wideband boom microphone, DualFlow Audio, up to 110-hour battery life, lightweight 315-g design, plus ASUS Aura Sync RGB lighting
New
ROG Azoth Extreme
ROG Azoth Extreme 75% gaming custom keyboard featuring a full aluminum alloy chassis, carbon fiber positioning plate, adjustable gasket mount, full-color OLED touchscreen with three-way control knob, extended wrist rest, magnetic feet, tri-mode connectivity with 2.4 GHz SpeedNova technology, hot-swappable pre-lubed ROG NX mechanical switches, and Mac support
ROG Keris II Ace
The ROG Keris II Ace is an ultralight 54-gram ergonomic gaming mouse with a shape tested by pro FPS players. Equipped with 42,000-dpi ROG AimPoint Pro optical sensor, ROG Optical Micro Switches and the ROG SpeedNova wireless technology, the Keris II Ace is also able to enhance gaming performance even further with the ROG Polling Rate Booster, which supports polling rates up to 4,000 Hz in wireless mode and up to 8,000 Hz in wired mode.
ROG Cetra True Wireless SpeedNova
Bluetooth® and 2.4 GHz wireless gaming headphones with ROG SpeedNova wireless technology, 24-bit 96 kHz audio and Dirac Opteo™, Bone-Conduction AI Microphones, Adaptive ANC with Auto mode, up to 46-hour battery life, Hybrid Multipoint, plus ASUS Aura RGB lighting support
ROG Strix Impact III Wireless
The ROG Strix Impact III Wireless is an ultralight 57-gram compact gaming mouse that features ROG SpeedNova wireless and Bluetooth® modes with long-lasting battery life. The ROG AimPoint optical sensor offers precise tracking, and the ROG Omni Receiver allows for connections to a keyboard and mouse via a single dongle.
ROG Scabbard II EVA Edition
ROG Scabbard II EVA Edition gaming mouse pad with EVA-inspired design, protective nano coating for a water-, oil-and dust-repellent surface, with anti-fray, flat-stitched edges and a non-slip rubber base
ROG Strix Scope RX EVA-02 Edition
ROG Strix Scope RX EVA-02 Edition optical RGB gaming keyboard for FPS gamers, with EVA-inspired design, ROG RX optical mechanical switches, all-round Aura Sync RGB illumination, IP57 waterproof and dust resistance, USB 2.0 passthrough, and alloy top plate
ROG PBT Doubleshot Keycap Set for ROG RX Switches
The ROG PBT Doubleshot Keycap Set for ROG RX Switches offers gamers premium, durable PBT material keycaps for ROG RX Optical Mechanical Switches, providing longer lifespan and better keystroke feel.
ROG Strix Scope II RX
ROG Strix Scope II RX gaming keyboard with pre-lubed ROG RX optical switches, IP57 waterproof protection, sound-dampening foam, PBT doubleshot keycaps or UV-coated ABS keycaps, streaming hotkeys, multi-function controls, three tilt angles, and wrist rest
ROG Gladius III Wireless AimPoint EVA-02 Edition
The ROG Gladius III Wireless AimPoint EVA-02 Edition is a 79-gram wireless gaming mouse that features the 36K-dpi ROG AimPoint optical sensor, tri-mode connectivity, ROG SpeedNova wireless technology, swappable mouse switches, ROG Micro Switches, ROG Paracord, 100% PTFE mouse feet, and mouse grip tape.
ROG Falchion RX Low Profile
ROG Falchion RX Low Profile 65% compact wireless gaming keyboard with ROG RX low-profile optical switches, tri-mode connection with ROG SpeedNova wireless technology and Omni Receiver, protective cover, integrated silicone dampening foam, interactive touch panel, and MacOS support
ROG Strix Scope II
ROG Strix Scope II gaming keyboard with pre-lubed ROG NX Snow and NX Storm mechanical switches, sound-dampening foam, PBT doubleshot keycaps or UV-coated ABS keycaps, streaming hotkeys, multi-function controls, three tilt angles, and wrist rest
ROG Moonstone Ace L
The ROG Moonstone Ace L is a large gaming mouse pad made of durable tempered glass, featuring an ultrasmooth surface optimized for fast, consistent mouse glides and an anti-slip silicone base.
ROG Strix Scope II 96 Wireless
ROG Strix Scope II 96 Wireless gaming keyboard with tri-mode connection, streamer hotkeys, multifunction controls, hot-swappable pre-lubed ROG NX Snow & Storm mechanical switches, ROG keyboard stabilizers, PBT doubleshot keycaps and silicone dampening foam, three tilt angles, and wrist rest
ROG Hone Ace XXL
The ROG Hone Ace XXL is an extra-large-sized gaming mouse pad with a base made out of an extra-soft, anti-slip rubber, and has a hybrid cloth surface designed for consistency and optimal control, while being water-, oil- and dust-repellent.
ROG Desk Mount Kit ACL01
ROG Monitor Desk Mount Kit ACL01- 23.8- to 49-inch ROG monitors*, Mounting base, C clamp.
ROG Chakram X Origin
ROG Chakram X wireless RGB gaming mouse with next-gen 36,000 dpi ROG AimPoint optical sensor, 8000 Hz polling rate, low-latency tri-mode connectivity (RF 2.4 GHz / Bluetooth / wired), 11 programmable buttons, an analog joystick and hot-swappable micro switch sockets (mechanical / optical ).
comparison icon
Compare (0)
